Please help I am at my wits end. I have a four door 97 Tahoe with only AC in the front. It was blowing warm air so I "evacuated" the system and then put a vacuum on it with an actual vacuum pump (instead of using an air compressor and that red mickey mouse vacuum conversion pump thingie like I tried before) vacuumed it for 25 minutes then shut off the valves and let it sit there for 30 minutes. It sat and held the 40 PSI vacuum just fine.
FIRST ATTEMPT - Plan A
Then I connected a 14 oz can of freon to the middle hose and expected it to get sucked in without even turning the car on, but it sucked a bit in then I had to start the car and blast the AC and the clutch would not spin.
SECOND ATTEMPT - Plan B
So I disconnected the gauges and connected the can with one of those quick charge blue hoses with a dial on them directly to the low side service port and ran the engine and after what seemed like for ever finally the clutch started engaging for about 5 seconds then shutting off and cycling off and on like that, but still not pulling any freon.
Just so you know I have charged this car and others like this in the past, well... before that stupid blue base cap came out that they make you put on the cans now first before connecting the charge hose to them. And yes I do have the blue base cap and I am using it, but something just aint right.
Please help.
Please help.
