ABS lamp
nzvlnr
1994 Chevy Blazer v8
I have an abs lamp when the vehicle starts moving and it stays on....( it will lamp up if I sit there as well).
How do I test the sensors to see if one is bad?
MO Viet Vet
Soon to be Missouri
Check to see if they are out of adjustment or dirty or has a bad wire or connection. If you have been in the mud or muddy/salty roads lately it could be as simple as that.
nzvlnr
Actually the truck has had this ever since I bought it 3 years ago..I have done a front brake job on it abt 500 miles ago.....I cleaned the sensors.....how do I check for a bad one? I am selling it and would like that lamp to be corrected.
Ohm out the sensors. there are 2 on the front and the VSS is for the rear wheels, the ABS module is probably bad tho.....
nzvlnr
Can I pull the code to find out what is bad...or does a shop with the proper ODB I tester need to pull it....scan tech II is the scanner?
adam74
MAGNOLIA TX
put a paper clip between two ports on the obd1 plug and check them as if you were checking the cel codes. let me try to see which ports they are again cant remember off hand
adam74
MAGNOLIA TX
OBDI, which means you can get the codes using a paper clip. just find the little data link connector thing just under the dash below the steering column. you need to make the connection between the A and H terminals: A (ground) is the the top row on the very right; H is on the bottom row, second square from the left. watch the <font color=red>anti-lock</font color=red> light on the dash...count the flashes in groups...for instance, a group of 4 flashes and a group of 3 flashes means a code of 43.
Sounds right Adam, didnt want to try to explain something I couldnt remember all the details on tho.....
nzvlnr
Ok...A and H....I will look for the pin out on the ODB I ...I was under the impression that codes for the ABS needed to be read from a SCAN II device?
Anyone have the pinout on the ODB I? I am not at home with all my documents....looking now
adam74
MAGNOLIA TX
yeah you could pay a shop to read em for you or you can do it yourself for free lol
nzvlnr
Awesome......much appreciated....Happy New years to ya!
nzvlnr
So I paper clipped pins A and H and I get a count of 1 and 4....Problem is there is no code for that. There is a high temp code, but I am pulling codes for the ABS not the engine diagnostic?
MO Viet Vet
Soon to be Missouri
I binged this....
ABS code 14
A code 14 is the Enable Relay circuit open. It could be a bad ground, a bad Enable Relay or the Abs hydraulic unit is defective.
nzvlnr
I binged this....
ABS code 14
What is an enable relay and how do I track something like that down? I guess a schematic would be the way to track it down?
Ice98
I have heard of this problem being quite common, what happens is that the actual sensors in the wheels will have any number of things happen to them, either wearing out, becoming corroded, spacers wearing out, etc, its pretty easy to check and replace the sensors but you will need a decent multimeter
https://www.youtube.com/watch?v=Ld5-eoYGAiA
