A/C setting #1 acts like vent...
rdfamily
Fort Bragg, NC
My 1st blower setting acts like it's on vent instead of blowing a low amount. If I turn it up to 2 it's way too high...and even higher for the other numbers. I only get good air flow from 1 if I'm driving...idling gives me no flow.
Suggestions?
RenegadeTahoe
Suggestions?
Turn it to recirc. The air you're getting is the outside air being forced through the system. It's like taking a floor fan and turning it to the lowest setting... then blowing air through it....
If you turn it to recirc, it closes off the outside vent, thus having even airflow at idle and at speed. ;)
oomindwarpoo
CA
It will always blow air in either way, put it to the head/feet setting and have it on 0 is the best way to minimize the effect.
rdfamily
Fort Bragg, NC
I don't understand what you mean. I WANT it to blow...it doesn't. Basically there is no blowing going on in the 1st setting.
