99 Yukon Radiator Drain Plug
wn6wtv
SF Bay Area
Pray tell, what do I need to remove or modify to gain access to the radiator drain plug? I can't even see it, much less lay hands on it!
Drivers side bottom corner of radiator, reach up from below and turn the drain, perhaps the radiator doesnt have one?
Mayhem
Broken Arrow Oklahoma
Prolly just like the Tahoe. The plug, it's flat, no tools should be required but maybe a pair of pliers.
wn6wtv
SF Bay Area
I found the little dude. Above info correct - left (driver's side) at the bottom. Service manual says remove with 1/4 in ratchet - I can't reach it, either from below or from going in past the brake fluid reservoir. I'll just have somebody flush it.
So much for do-it-yourself.
Thanks all........
