This diagnostic should only be used if all door lock motors are inoperative from all switches.
Has the Power Door Locks System Check been performed?
Go to Step 2
Go to Power Door Locks System Check
Connect a J 35616-200 test lamp between CKT 640 (ORN) at LF door lock switch and ground.
Does test lamp light?
Go to Step 3
Go to Step 14
Gain access to the Door Lock Relay.
Connect a J 35616-200 test lamp between CKT 540 (ORN) and ground.
Go to Step 4
Go to Step 15
4
Connect a J 39200 DMM, set on Ohms, between CKT 150 (BLK) at Door Lock Relay and ground.
Is there continuity?
Go to Step 5
Go to Step 16
5
Connect a J 35616-200 test lamp between CKT 294 (TAN) at Door Lock Relay and ground.
Move LF Door Lock Switch to the UNLOCK position.
Go to Step 6
Go to Step 9
6
Connect a J 35616-200 test lamp between CKT 295 (GRY) and ground.
Move LF Door Lock Switch to the LOCK position.
Does the test lamp light?
Go to Step 7
Go to Step 10
7
Connect a J 39200 DMM, set on Ohms, between CKT 295 (GRY) at Door Lock Relay and ground and CKT 294 (TAN) and ground.
Is there continuity in both positions?
Go to Step 8
Go to Step 13
8
Repair open in CKT 294 (TAN) or CKT 295 (GRY) between Door Lock Relay and door lock motors. Refer to Wiring Repairs in Wiring Systems.
Is the repair complete?
9
Connect a J 35616-200 test lamp between CKT 194 (WHT) and ground.
Go to Step 11
Go to Step 12
10
Connect a J 35616-200 test lamp between CKT 195 (LT BLU) and ground.
Move the LF Door Lock Switch to the lock position.
Go to Step 11
Go to Step 13
11
Replace the Door Lock Relay.
12
Repair open in CKT 194 (WHT) between Door Lock Switches and Door Lock Relay. Refer to Wiring Repairs in Wiring Systems.
13
Repair open in CKT 195 (LT BLU) between Door Lock Switches and Door Lock Relay. Refer to Wiring Repairs in Wiring Systems.
14
Repair open in CKT 640 (ORN) between I/P Fuse Block and Door Lock Switches. Refer to Wiring Repairs in Wiring Systems.
Do the door locks function properly?
Go to Step 3
15
Repair open in CKT 540 (ORN) between I/P Fuse Block and Door Lock Relay. Refer to Wiring Repairs in Wiring Systems.
Go to Step 4
16
Repair open in CKT 150 (BLK) between Door Lock Relay and G202. Refer to Wiring Repairs in Wiring Systems.
Go to Step 5
Document ID# 377454
1999 Chevrolet Tahoe - 4WD
