smackleboom
- May 17, 2015
Hi all let me start by saying never in my life I thought a Chevy could defeat me:sad72: I bought a 99 Tahoe a few weeks ago because the owner could not get her to run properly. It would start and idle ok but touch the gas peddle and it bogs, backfires,and barely goes above 1500 rpms.i read through these forums for a few days then I attacked. So far the previous owner had put in a new distributor with cap and rotor and a new fuel pressure regulator. I have put in fuel filter, spark plugs,front O2 sensors,new timing chain and gears, intake gasket,and did the camshaft retard to 0% at 1000 rpms. I'm using a Genisis Newvo scan tool, I have no CEL but a p0154 and p0300 is pending. I am almost 100% sure that I don't have any vacuum leaks. My only discrepancy is that the fuel pressure is at 52-59lbs (with new regulator being verified) and the previous owner had the cats gutted.othewise all of my engine sensors have normal readings. That being said ....I'm convinced that what I did,needed to be done I don't want to randomly throw parts at her so I'm crying for help even though it's better in the Bahamas......parts ain't cheap
