99' tahoe factory speaker size?
Hardwarz
Ohio
Nice! Think 6x9's will fit back there? How did you run the wire?
Hardwarz
96ProCompTahoe
Indiana
should be able to run the wiring through the loom for the power lock. (not sure on the other side, can't remember if they have defrosters on the barn doors or not)
qlc1964
st.louis mo.
i used small gauge wire so it wouldn`t get pinched. i tried the wire loom
(very small )but closing the doors IT was crushing the loom door harder
to close.
i use a step bit and had to take rear lights off to get the wire inside the
cargo area fished the wire up where the wires for the lights come through
then back down. i have no pinched wire problem so far.
and the rear doors have 5 contacts so when the doors is close the locks&def
then have current to them(no wire loom)
