98 Tahoe wont start w/o starting fluid
cecilville
The Tahoe runs great but wont ever start unless starting fluid is used. Cant find any leaks and have 40 lbs of pressure before starting and 50-60 after running. Does have a po122 trouble code but its for TPS. Will that cause no start ?
Usually the starting fluid means battery voltage is low or pump pressure output is low.
cecilville
Thanks for the input. thought that might of been the issue. good battery output so I will attack the pump
Might put key in run position a few times and then crank it to see if it starts, still sounds like pump....
