98 tahoe transmission noise question
MO Viet Vet
Soon to be Missouri
When you insert that torque convertor make sure you turn it and push in lightly and feel the "step" process as it engages. That front seal should be replaced if is old and when install the convertor a thin film of grease is ok at the seal lip area for slickness. Also check the snout of the convertor to make sure not grooved.
argclh6670
Good call on the seal.....afew extra bucks is worth th piece of mind. Couple questions, theres a seal retainer clip, is that reusable? And, with tc fully engaged i spin it and it growls (seated too far) i pull it out a 1/16 and spins freely no nise. Is that normal??
MO Viet Vet
Soon to be Missouri
Yes on the clip as long as is spring steel and in good shape. The growl is the gearing moving. When you pull the convertor forward to bolt to flex plate it is same as what you just described.
argclh6670
K people, installed the trans on saturday....everything feels good....shifts well, no odd noises. So i think this one is whooped. Thanks to all who commented! This Forum rocks!!
