98 Tahoe O2 sensors?
Beltrmd
Hello
My sister's 98 Tahoe has the following trouble codes:
P0133: oxygen sensor slow response bank 1 sensor 1
P0155: oxygen sensor heater circuit bank 2 sensor 1
P0301: cylinder 1 misfire detected
P1133: oxygen sensor insufficient switching bank 1 sensor 1
P1153: oxygen sensor insufficient switching bank 2 sensor 2
P1351: ignition coil output high/pulse detected - ground cylinder 1
Any help or suggestions?
Beltrmd
Can someone tell me if I need to replace 3 sensors? Also which one is bank 2 sensor 2?
Sensor 2 would be the one AFTER the CATALYTIC Converter and is irrelevant to function if bad.
Sensor 1 would be BEFORE the CATS and is important.
Bank 1 is drivers side
Bank 2 is Passenger side.
P1351 may be a bad ICM
P0301 may be a bad cylinder due to low fuel pressure or ignition or cylinder damage.
You will need to do some more investigation (check fuel pressure/ spark plug look, etc.)
