97 Tahoe...Rear looks saggy...
Biggwaukegan
Common problem with these tahoes..looking at the truck from a distance it looks like the rear of the truck sits a tad lower than the front. had the new shocks and put on it and it rides great, but i sure would like it to have the rear end up a lot higher. any suggestions? thanks:Chevy:
chevyrider
Northern, IL.
If your leafsprings are above the axle it is fairly simple to get rid of the sag and even gain a couple inches. Your stock riser block is probably 2 in. so if you want to boost up your back end you could add a 3 in. block or even a 4 in. block for a 1 or 2 in. rise. You can do this yourself if you have the tools or go to an auto shop and have it done complete for probably 150 bucks. just look online for leveling kits and riser blocks, you dont have to do the front end so you dont new torsion bar keys.
Hardwarz
Ohio
What if i found the 2nd to last leaf snapped in half right by the bolt? :cryin:
Hardwarz
Biggwaukegan
ok so i need the springs and some 3 inch blocks right? and i dont think the 07 parts are gonna help, but thats dam cheap..:smilielol: Springs and blocks for the rear..thanks guys:Chevy:
qlc1964
st.louis mo.
rear sag
i put air shocks on my 95 yukon i got the rear slightly higher than the front.
no ride problems. paid 60.00 at auto zone 2 yrs ago
1999HOE
Massachusetts
i would def try the air shocks first super easy and cheap to do as a first step
qlc1964
st.louis mo.
rear sag
these are life time warranty to. when the weather here warm up i will change them.
Biggwaukegan
Where is the riser block located? got any diagrams? thanks..
sasquatch094
ohio
go to belltech.com and see what they have up there.. theres millions of parts you could get to raise and lower your truck.. anything could help that little "sag" of yours..
chevyrider
Northern, IL.
The riser blocks are located just underneath the leafsprings of the rear axle. If you look at the rear end of the axle and you are riding on leaf springs then you will see the stock block with stock u bolts attached, if you were to change them out you could add a 2in. block to add 2 inches or a 4 in. block to add 4 in. etc.
CRXMotorsports
MidOhio
Here's another thought.. I got them at a great price, but it definitely gives me a 0-4"+ adjustment for the rear.. the original reasoning though was for towing the race rig around, unfortunately, since I've done them late last fall, as well as other modifications, programming, etc. I haven't had the race car & trailer around to tow. D'oh!
