'96 Z71 Skidplate
96ProCompTahoe
Indiana
Just discovered my truck came with the Z71 Package and it lists the Z71 Skidplate in the RPO codes.
now where is this skid plate supposed to be? i have a feeling mine dissappeared somewhere along the line of owners.
Razincayne
SE Washington State
Actually you should have two of them with RPO NZZ. The front one is an all aluminum front underbody shield starting behind front bumper and running to 1st cross-member protecting front underbody, oil pan, and differential case. The second is an all steel frame-mounted shield that protects the transfer case.
96ProCompTahoe
Indiana
the T-case plate is still there, but the front plate is long gone then.
thanks for the Info.
clean95
sacramento
are u talking about the codes in the glove box? are those pro codes? if so whats the z71 code? and where did u find the dictionary for those codes?
