also on the throttle assembly drivers side. the tps is the foward most one the iac is towards the rear. the iac is mounted by 2 torx screws. unplug it, remove both screw and clean tip as well as the chamber it mounts into. make sure gasket stays on iac and not in chamber if it does stay in chamber remount on iac. also while your at it get a can of maf(mass air flow) cleaner at your local parts store and clean that as well. that is the electonic part mounted in the air cleaner hose assembly. they get dirty over time. good luck.
