5.7 to 6.5 turbo diesel swap
tahoebush
29 palms
Hey guys,
I have a 1995 4 door tahoe 4x4 LT. Im really thinking about putting a diesel motor in it. the 6.5 turbo diesel
i know there will be lots of work involved.
6.5 motor
transmission- which one?
new fuel tank
computer
exhaust
i know i missing a whole lot more. is it even worth it?
thanks
Jounier11
Los Angeles, Cali
:gasp: Where in the world did u get the 6.5 Turbo Diesel that are only found in 0.001% of 96-99 Tahoe's? :confused: OHH P.S. these got the 4L80-E Tranny :D
tahoebush
29 palms
I'm really into bio-diesel. I got a buddy from motor t. That can get me an old 6.5 from out of the humv. I know it's gonna cost. But if I can do it for under 5-6 grand. Then I'll prolly do it. I'm a decent mechanic and I know how to spin wrenches. And I couldn't afford the gmc 2500 4x4 I really wanted.
It's got the 5.7 in it right now with about185,000. And it's really starting to show wear.
Jounier11
Los Angeles, Cali
Well im 92% positive you will not spend more than 6k just make sure that engine won't give you problems! Good Luck :D
Rd05lly
Auxvasse, MO
Find a donor truck because you are going to need a lot of stuff... Bio-diesel is ok run a Cat fuel filter with additive if you do it.
The frame on the front of the truck may be a little insubstantal for a diesel as they do weigh alot more, will need some suspension stuff too I suppose.......
tahoebush
29 palms
thanks guys. this info is awesome. this is my first tahoe. im more of a motorcycle mechanic. but im trying to broaden my abilities. so Thanks for your help
97 T Hoe
I say go for it, but I would get a donor truck, swap all the diesel parts and then put your gas parts in the truck. Then sell the truck.
I want to convert mine, but was leaning toward the 4bt cummins.
If you do it, good luck.
blk90tpi
The factory 6.5L had bigger brakes, Hydroboost Master cylinder, bigger 2500 suspension and 4L80 transmission.
I wanted a 6.5 badly.. That is until I bought my '95 2 Door..
Nothing but expensive problems until it threw a Rod through the pan, while on the Expressway last year.
Replaced it with a 4 Door Gasser and pulled all my new parts off the 2 Door..
Good Luck
