jjaawilco45
- Mar 16, 2014
how far should the 4wd actuator extend, I've got a problem with my system. i've checked all of the fuses, i don't have a vacumn system. the system seems to select different modes of 2 or 4wd. but when in 4wd (high, low, or auto) there seems to be a serious binding issue in the front end( especially bad when in reverse) I have followed some of the advice that i've seen here, but haven't found anyone that appears to have an issue similar to mine, i've removed the 4wd actuator, started the vehicle, and selected different modes on the dash switch. the actuator extends and retracts fine,( i think) i've measured it to be about 7/8 of an inch. is that a go or no go
thanks, jeff
thanks, jeff
