Look above the actuator on the diff to see if there is a 2 pin connector. This is what is used on the thermal actuator type to determine if the diff is actually engaged or not.
I think that since your truck is a 97 it should have the motor type actuator. I believe that 96 was the last year that the thermal actuator was used on 1/2 ton trucks but I can't state that as a fact, someone else may know.
The actuator is available at an auto parts for less than $100.
