I have a 2005 Yukon and my 3rd brake light is out...do I have to replace the whole assembly to get that working again? I didn't see that it was just a bulb?
Be sure to check your fuses before you go replacing the light, I believe that the 3rd brake light is on its own fuse instead of sharing the main brake light fuse. Also, you should be able to use a test light and see if you are getting voltage to the 3rd brake light when you push down on the brake pedal.
