Picked up a 2000 tahoe a month ago and it seems the heat is not working. It worked the night I bought it, not the next night. Since then it either doesn't work at all (usually) blows warm at best (sometimes) or works fine (rarely). The hottest it will blow out the dash is as hot as the rear heat will blow, but I thought the rear heat had a separate heater core....? It seems the issue is universal between the front and back because when it doesn't work at all on the dash, the rear heat is the same, no heat.
I found the cabin filter was extremely plugged so I replaced that. Also, is I grab the heater core lines under the hood one is very hot and the other is just hot... So it seems the core may be working fine.
