07 tahoe procharger
chris10an
Norway
that is a cool build your doing. what are the specs on the LS1 shortblock? im assuming it isn't a stock bottom end...
Jeremy[/QUOTE]
Hi again here is the specs:
04 Ls1 Alu Block.
CompCam xr 281 hr cam
Gm 317 Heads.
90 mm inake with Vette LS2 Throttle Body.
H-B rods.
Diamond plasma pistons 20 PSI
Original crank. handle up to 1000hp.
1/75 roller rockers.
one modyfied P1-SC Procharger with GTO setup. intercooled. Picture comming later. As you can se we use the orignal coils
