07 Tahoe Issue: No power in passenger door
Martian097
St Louis
I did a search, but didn't find anything that matched both symptoms.
I am having a problem with my wife Tahoe. 2 days ago, the Passenger side power door window and power door lock stopped working. I have gone through the fuse in the driver side panel and the circuit breaker under the driver side also. All check out okay. I even went through the fuses under the hood, but all to no avail.
I am wondering if there may be a connector that has come loose in or around the door? My daughter has a tendency to get PO'd and slam the door, so wondering if she might have knocked something loose. :fca5278d:
Also, if it may be in the door, any tips on getting it disassembled would also be appreciated. --Thanks
Martian097
St Louis
No ideas? If it helps any, it appears that the speaker in the passenger door is also not working, but that happened before the power issue.
Martian097
St Louis
Bump. Everything is isolated to the front passenger only. No power window, lock, mirror and sensor for open door all stopped working. Been through the fuse boxes under hood and driver door as well as the CB box under the driver dash. Any help at all would be greatly appreciated.
