im a tech work for Honda I checked some thing the truck was parked for a week it rained pretty hard came out it doesn't start cranks but doesn't turn over
I checked for fuel first pump primes and fuel at the rail strator valve
I checked for spark no spark
I checked all under hood fuses
I then checked power and ground at the coil pack connector good
I was checking the 2 middle pins for signal I had .09 wit ign on and about .014 while cranking not sure if the value is good
I also inspected the pcm looked at all the pins and harness and checked the seal around the connectors which look really good
I replaced both ckp and cmp sensor still nothing
I looked into the theft detterent system I armed the truck light stays solid for about 15 sec then goes off and when I turn the key to run it comes on and goes off assuming there no problem im stuck right now
im assuming pcm all suggestion would be appreciated thanks
prior to all of that the truck ran great not 1 prob this just uped and happened any suggestion I really don't wanna tow it to a dealer
