Hi Silky, yes it is easy actually the bolts are not pressed inn, but merely inserted.
When you tried to loosen up the nut on the bolt-pin, the whole pin started to turn and forced itself in the sidewalls of the plastic. I had the same problem. You can easily turn the pin back a bit with a pliers and then you can take out the pin and replace with new one. I found complete replacement fog units incl the 2 pin-bolts for 18 bucks.
