samotahoe
double check that pcv again. ive seen too many times that would be a culprit in rough idle and load situations. also if you have access to a back pressure tester I would see how much back pressure you have. might be the cats. my main worry is in the picture there is a lot of debris. we have a lot of tahoes and ford trucks that come in and there would be rats nest under the manifold. and rats would chew up the wires. I would definitely double check wiring to make sure theres no breaks in a sensor wire that could be causing all these issues for you.
