Ok here is my experience..I went by another forums suggested vendor,called and confirmed application and their best suggestion.The company Is The Retrofit Source or TRS
This was not a cheap Chinese kit so I thought.I did the install anyway and the fit and finish and quality are NOT all the hype they state.
Cheaply made harness with a relay that could fall out as it does not lock in or even have a bracket,poor light output with a delay at each turn on (even though 55 watt),one relay for both lights,fuse not weather proofed and in general cheap.
BTW they;TRS; suggested 55w and I found 2 things-
55w watt output AND the cheap non UV bulbs will damage the projectors over time.Factory output is 35w
I wrote it off because there support is very deceptive and not helpful,of course I find after the purchase that the reviews are the same.
So I do my research and buy the Xenon Depot 35w deluxe with Phillips bulbs for the same money and What a difference.The fit,quality and overall light pattern is for superior and had Phillips Bulbs,a relay for each headlight,sealed relay and fuse..no chance of projector damage in future.
I hope this helps others in their decision to upgrade to HID.
The first pictures are the TRS kit-I will add the Xenon Extreme kit pictures after those in a separate post
