HID Kits-TRS vs Xenon Depot
69meano
Ok here is my experience..I went by another forums suggested vendor,called and confirmed application and their best suggestion.The company Is The Retrofit Source or TRS
This was not a cheap Chinese kit so I thought.I did the install anyway and the fit and finish and quality are NOT all the hype they state.
Cheaply made harness with a relay that could fall out as it does not lock in or even have a bracket,poor light output with a delay at each turn on (even though 55 watt),one relay for both lights,fuse not weather proofed and in general cheap.
BTW they;TRS; suggested 55w and I found 2 things-
55w watt output AND the cheap non UV bulbs will damage the projectors over time.Factory output is 35w
I wrote it off because there support is very deceptive and not helpful,of course I find after the purchase that the reviews are the same.
So I do my research and buy the Xenon Depot 35w deluxe with Phillips bulbs for the same money and What a difference.The fit,quality and overall light pattern is for superior and had Phillips Bulbs,a relay for each headlight,sealed relay and fuse..no chance of projector damage in future.
I hope this helps others in their decision to upgrade to HID.
The first pictures are the TRS kit-I will add the Xenon Extreme kit pictures after those in a separate post
69meano
Xenon kit pics
xenon Kit Pics
