Motor mounts in 2007 LTZ 5.3L are bad (driver side broken, passenger side worn - according to dealer).
I successfully replaced the driver's side mount (there was a lot of clearance to work on that mount) and now working on the passenger side (there is way less clearance to work on this side).
I can get all 7 of the bolts free on the passenger side mount - but am unsure how to extract the mount from its space (and position the replacement) since it is obstructed by the starter to the rear, AC compressor to the front and motor & frame to the sides along with some transmission cooling lines.
Can someone please provide technical info on removing the mount ? Does compressor have to come off ? Engine lifted ?
Thanks for your help !!!
