XenonDepot
- Sep 11, 2008
Xtreme DIGITAL HID Kits ON SALE!! - Only $174.99*
LOWEST PRICE EVER OFFERED ON THESE KITS!!
* Selling Quality lighting products since 2001!!
* CE, UL, and E4 certified OEM Grade Xenon HID Components!
* Full replacement warranty!
* Patented Digital Ballast Technology for precise colour illumination!
* Trained & Knowledgeable Staff!
* Unique dual relay harness design!
* We will NOT sacrifice quality!
The Xtreme HID Conversion kits utilize cutting edge HID components made with superior Japanese craftsmanship and quality. These kits are manufactured in a high tech facility that is ISO and TUV certified!! Laser calibrated bulbs are used to ensure proper fitment and optically correct beam patterns. Don't sacrifice quality when it comes to your car!
The ballasts used in this product are uniquely designed for aftermarket applications as they are rubber injected to protect against harsh weather conditions. In aftermarket applications, ballasts are often mounted outside the headlight leaving them susceptible to water damage. The Xtreme ballasts are specifically designed for these applications making them the superior choice for your aftermarket HID upgrade.
BALLAST SPECIFICATIONS:
- Xtreme HID ballasts are designed with a patented multi stage safety feedback (M.S.S.F.) system allowing them to interact with the bulbs to determine optimal light output.
- Xtreme HID ballasts use a patented self intelligent light output configuration (S.I.L.C) to ensure brightness stability and precise illumination colour.
- The Xtreme HID ballasts are designed for both 12V and 24V applications.
- Equipped with advanced polarity protection system
This product will include 2 complete wiring harnesses - 1 per side that will literally plug directly into your OEM headlight harnesses via proper mating connectors. The harnesses provided will include upgraded fuses and relays to ensure you do not draw a higher current from your stock wiring harness than it was designed to provide. Unlike many kits on the market, each harness will be completely independent of the other so should a fuse ever fail, you will still have a functioning headlight. Most other HID kits that come with a harness use a single relay/fuse design that will result in you losing both your headlights if the harness fails. Our harness will ensure that the ballasts get a constant 12V and will also protect your vehicle's OEM wiring.
Please click here for some non biased reviews and customer testimonials:
http://www.kbcarstuff.com/SearchResults.asp?Cat=61
Our products are backed by a one year warranty. A warranty is only good as long as your vendor stays in business. We have been selling HID kits since 2001 and have been a reliable vendor on various automotive forums since 2001. Our goal is to offer our customers quality lighting products with a higher level of support/service!!
Please enter this coupon code to obtain your discounted price upon checkout: TF
FITMENTS:
Available Fitments - H1, H3, H4 (9003), H7, H8, H9, H10 (9145), H11, H13, 880 (9008), 9004, 9005 (HB3), 9006 (HB4), 9007
Colour Temperatures available - 3000k, 4300k, 5000k, 6500k, 8000k, and 4300k with Philips bulbs
You can find our Xtreme HID conversion kits listed here:
http://www.kbcarstuff.com/Xtreme_Digital_H...n_Kits_s/21.htm
Make your installation safe! Get a FREE pair of Nylon Nitrile dipped gloves!!!
The ideal glove for installing our HID lighting products!
Our contact information:
Email: [email protected]
Phone Number: (905) 660 0124
**All orders placed at this discounted price will still be included in our monthly draw to win a free HID conversion kit
Regards,
Steve
* starting at $174.99
