this is a bumper cover? hmmmmm... sounds cheesy
plus, i dont think this will work with the z71 front bumper
1. Remove the factory lower valance.
2. If your vehicle has factory fog / driving lights remove them & zip tie the wires to keep them out of the
way. NOTE: Your factory fog / lights will no longer be connected.
3. Clean the upper cap on bumper with a suitable cleaner to promote adhesion of tape.
4. Clean the top underside of bumper cover as you did to the upper cap.
5. Apply the two sided tape to the underside of the S/S Bumper Cover. Leave the backing on at this time.
6. Place the bumper cover over the front bumper.
7. Drill two holes on each side through bumper cover and into the steel bumper. Install the screws provided.
8. Remove the backing from the two sided tape and apply pressure to adhere the tape.
these are the instructions to install it. if you have to remove the lower valence then you should be ok because that is the only differnece on a Z71 bumper and a regular Tahoe bumper.
i have not been able to find a real replica SS bumper replacement only the cover
