ive got a 2003 tahoe with the 4.8.
Had to change alternator which led to changing the battery. its a duralast from autozone with 1000 cranking amps. not sure if it is the correct battery. the wife went get it.
anyway, the truck idles as low as 400 then jumps to about 800 every 15 seconds or so. if i have the AC on it has died out while im in park on the brake.
i took off the air intake to get to the belt to take the alternator off. could i have screwed the idle?
i notice my HID's have a subtle blink every now and then. should i be concerned with that?
any advice is appreciated.
