Turn Signal Gremlins
compoundtrey
My turn signal relay is clicking the whole time the the truck is running.
if my headlights are off, the left turn signal indicator will be mostly off, but flicker a little...the left turn signal and parking lights will flicker
with headlights on, the turn signal indicator will be intermittently on and the left turn signal/parking lights flash like I have them switched on.
now the rear lights don't activate unless I flip the turn signal switch...
this problem only seems to affect the front left turn signal and no other....
I unplugged the tow harness at the rear to see if anything changed, nothing...
tried a new relay.... nothing
anyone else have this trouble?
I have Anzo headlioghts and marker lights
halogen bulbs in lows and highs and led bulbs in markers and turns...
tail lights are stock
Sounds like your MFC switch is bad (the turn signal stalk switch), these can go bad and have various different issues since all the lights are run through them...
