Transplant a 2010 5.3L into a 2000??
ZBrink
Springfield, IL
I have the opportunity to purchase a 5.3L out of a 2010 Yukon. What would be required to place this into my 2000 Yukon? What parts are different? Would it be easier and would it work to use much of the parts off of the 2000's engine by only using the block and heads off the 2010??
Thanks,
Zack
the-hoe
Pittsburgh
I would first ask why you would want to swap it out? there are some aluminum 5.3s in the newer vehicles. I believe your old engine would be a gen III engine while the newer one would be a gen IV. this means that the injection system would be a returnless one, the knock sensors might be on the side of the block like ls2s instead of under the intake, it could have lifters for VVT and could utilize active fuel management , front mounted cam sensor, and 58x reluctor wheel. Now please realize that this info is only known by me because i changed to a GEN iV in my tahoe a few years back and these were things I had to deal with. i re-wired my knock sensors, and my cam sensor (which requires switching wires and a tune) I believe you can tell if your new engine is 58x or 24x by the color of the sensor. ummmmm grey means 58 and black is 24 possably. I only remember that from someone elses post. If i was you i would look up information on swaping from a gen3 to a gen 4 i wish I could help more, but I did it a long time ago and i go not have my schematics for wiring up the sensors and sutch. good luck, if you have more questions just ask
ZBrink
Springfield, IL
The factory engine in my 00' Yukon has 200k on the clock. A local guy has a 5.3L out of a 2010 with only 700 miles and he wants peanuts for it.
I figured if this was something easy enough to tackle I could swap merely the block, heads and exhaust manifolds while utilizing my current intake manifold, throttle body, fuel rail setup and all accessories which are fairly new anyhow.
I forgot all about active fuel management and VVT!!
clkelley
Moderator
Galax, Virginia
Talk about detailed tech...hmmm :waytogo:
ZBrink
Springfield, IL
Again, what if I just use the assembled block, heads and exhaust manifolds from the 2010 and use the intak manifold, throttle body, fuel system, etc. off of my 2000??
Does anyone know for certain? Please don't guess.
