Transmission Cooler ???
Yomoe
Has anyone put one in? and if so, which one...the stock GM one or aftermarket?
Thanks in advance,
Bill
JennaBear
CA
There are quite a few threads around on this subject. I would search for those so you can see all the different opinions. I personally have a B&M on mine.
mgyver1
From the limtied research I've done there are many that have done it. Some install a general application one like a B&M or a Hayden cooler while most go the OEM route since it has the pre-bent tubing with all the correct fittings. I installed a tranny cooler on another vehicle and it wan't too hard so I plan on installing one on my Tahoe.
Here's the GM one for sale: http://chevrolet.dealerfit.com/store/chevrolet-tahoe-auxiliary-transmission-cooler-prod691_19881.php
I have two questions about this. One is about the towing option. I noticed one had it and I swore it said "engine oil cooler & transmission oil cooler." I have not found any GM part for an aux oil cooler which I would really be interested in. And 2, is about the police package tahoes. They supposedly have an upgraded cooling system, brakes, larger air intake, front brake vent ducts, other oil coolers (tranny, power steering, oil, etc) and lower springs. Now I would imagine most of these parts would be available for general retail. I know they would probably keep the ECU limited to cops since the govenor is set higher, etc, but where can we get a hold of these upgrades. I figure since they are designed to function under severe conditions then those upgrades on a normally driven vehicle would make it last quite a bit longer and you would never have a problem with overheating on any fluids.
73shark
KC, MO area
Welcome to the Tahoe Forum.
I think that the Z71 comes w/ an oil cooler. Might take 4.10 gears and 4WD, not sure. As to the police pkg stuff, I'd think any good parts man could get you that stuff.
kntrydr
ajax, ontario, canada
I have a police pkg Tahoe and it has a tranny cooler,oil cooler and brake duct coolers but as for the cooling system it seams pretty stock it does have elec. fans I am not sure if reg. tahoes have that it is lowered from a stock 2wd Tahoe but I can't figure out if its done with springs or spindles in front
