trans fluid leaking into transfer case
boaterbob
I have 2004 Yukon and trans fluid is leaking into transfer case...bad seal. So is it usually just the seal or a bad input shaft bushing or bearing on transfer case causing ths seal to go bad? Was thinking about a low mileage used or rebuilt case. Truck has 138k. Any thoughts?? Thanks
