TPMS with Cubb Tool Question 2005 Tahoe
Bald Jerry
I got a couple problems going on the 2005 Tahoe and just got two new TPMS AC Delco Tire pressure sensors installed today and they were not able to set them saying I needed to have the Dealer do it or get a Scan Tool...
Got it back both read Zero and stayed there the whole way home
Got the Cubb TPMS Tool from Tire Rack today at a great price and from what I am reading it says to just set it for your make, model, and year. Do your reset procedure so the horn beeps twice and got that. From reading it says just put it in "Scan" mode and did that and it gave me the sensor ID, what the PSI was, and said "Storage" at the bottom. I expected a horn chirp like doing it the regular way and never got that. I have done this many times and know to start with RF, LF, LR, and RR and horn beeps and all done.
Like I said above got the sensor ID, Pressure, but not sure what the "Storage" means and the cluster still reads Zero for those two sensor.
Anybody ever use the Cubb TPMS Tool? I know it has a copy, and a program mode, but everything I read just says do the procedure and scan them.
Something need to be done for them in the other mode to get them to communicate with the Tahoe? I would do it the old fashioned way, but got the tires at Costco and they use Nitrogen and cannot get Nitrogen anywhere.
I know this is probably something dumb I am doing and missing something and will be like DUH if someone knows the answer. I even waited after it scanned the tire and gave me all the info to see if I would get a horn chirp and nothing.
I would say the sensors have to be good because I am getting pressure readings on the scan tool and they are OEM AC Delco just like the other 2 old ones.
I should have added this... I had the "Flat Tire Symbol" on the dash and that went away and has not come back on... Just not getting why the tool says Storage and not being recognized by the Tahoe with pressure and sensor ID on the tool...
What am I doing wrong?
Bald Jerry
Solved
Not a clue why this did not work yesterday. I did the exact same thing and it worked perfect and got the readings on the dash and no "Zero" for the 2 new sensors, got readings on all 4 now.
This Cubb tool is GREAT... I got the Michelin's at Costco and get FREE tire pressure checks and they use Nitrogen, so no more letting like 10 pounds PSI of Nitrogen out when I rotate the tires to set the TPMS monitoring system just to add air to get them to relearn.
Right now Tire Rack has a closeout on these for 19.99 plus like 8 bucks for shipping and reading some Dealerships will do it for Free and some are 50.00 to 75.00 to do exactly what this 19.99 tool did so it paid for it self 10 minutes ago.
Simple to use just get your vehicle in relearn mode and hold the tool and let it scan the sensor in the tire and wait for your horn chirp, so no more letting Nitrogen out anymore.
What happened yesterday I have no clue why it did nothing after my 2 horn chirps, but like I said above it did it today. Weird, but I am happy it worked.
