Towing
mCEVANS
Hi, I'm hoping someone can help me out. I have a 2008 Tahoe LT and I'm trying to figure out how much I can tow and aside from a weight distribution set up would I need a cooler if I'm towing over 5900lbs or does it already have a cooler.
MO Viet Vet
Soon to be Missouri
Should already have the cooler. Use a weight distribution hitch but remember you are driving around a rig that is basically a 1/2 ton with a short wheel base and short light duty is not meant to tow heavy loads and the handling can be iffy with the short wheel base. 5900 lbs is ok on flat ground for that rig but pulling up hills can be hard on it and long hauls also.
