I recently reprogrammed my Tahoe with the Hypertech Max Energy. I did the regular fuel tune, increased shift points 200-300 rpm and the rev limiter by 500 rpm to make room for the higher shift points, and also increased the shift firmness.
This programmer just had a yes/no preference to increase the shift firmness--not different levels of torque management removal. I've been reading all I can about this Hypertech and I can't find anything that says exactly how dramatically it removes the torque management. I know the shifts are very snappy now, even at very low/part throttle...
I realize the snappier shifts are better for the tranny (less friction/heat generation) but how harmful are they on the rest of the drivetrain like the u-joints and the rear-end? How durable are these parts from the factory? Are they going to last 100k+ miles with the snappier shifts? Do you think I should reprogram it back to stock shift firmness?
