Hi Im new to the forum.
I have a 96 2wd 4dr tahoe with the 5.7 vortec.
Im having a issue I cant figure out.
Im getting a stumble or hessitation when at cruising speeds. Like a mis-fire.Also When I accelerate hard and let off suddenly it will backfire and set off the check engine light but only for a moment. Other than that theres no check engine light and there are no codes coming up on the scanner. It also slightly hesitates when up-shifting and sometimes back fires when up-shifting.This gets better after its been warmed up at idle for 10min or so and then driven 20-30 miles. Ive owned it for about 6000miles. I put a rebuilt 4l60e in it after puting roughly 900 miles on it. Which did not change/cure the upshift hesitation cruising speed stumble. Which leads me to believe it is not tranny related.Heres a list of new parts I've installed since the tranny install. All new parts.
Tps sensor
cap/rotor/plugs and wires
Universal joints front/back
Brake system flush
master cylinder
brake booster
Coolant system flush
heater core
Ive also cleaned my MAF sensor and all my intake tubing before the manifold. I was leaning toward the problem being. The upper intake manifold needs rebuilding? Also my exhaust pipes have massive leaks. Funds are pretty limited at the moment. So I would kinda rather not keep shooting in the dark. ANY help would be greatly appreciated. Im new to the forum sorry if this is in the wrong place. Thanks Guys.
Tps sensor
Brake system flush
master cylinder
brake booster
heater core
