Top 3 Performance Tires for Chevy Tahoe - CARiD List
Performance tires are the key ingredient to proper acceleration, precise handling, and safe braking. Each major tire manufacturer offers performance tires, that are specially designed for trucks and SUVs in mind, whether it’s for smooth and quiet highway driving or weekend trips. If you are looking for the new tires for your Chevy Tahoe check out performance tires at CARiD.
#1 Yokohama Geolandar
https://www.carid.com/yokohama-tires/geolandar-g92c-1226283.html
- Latest generation drive axle tire
- Delivering superb traction in all weather conditions
- Casing and new tread design ensure even wear and top mileage for all needs
- Outstanding all-weather performance
#2 Nitto 420S
https://www.carid.com/nitto-tires/nt420s-453910.html
- The large outer tread blocks on this high-performance tire increase the amount of surface area in contact with the road. This improves dry cornering and handling
- Siping across the tread pattern provides additional biting edges to help maintain traction in wet weather conditions
- The center tread pattern effectively channels water for better wet-weather performance
- Slanted three-dimensional tread blocks reduce flex for improved handling
#3 Nitto NT421Q
https://www.carid.com/nitto-tires/nt421q-17905715.html
- Intelligent Maintenance Indicators
- Nitto's revolutionary 3D multiwave and 3D interlocking sipe design provides traction without sacrificing handling
- The circumferential rubber shoulder insert adds an additional layer of strength to help you navigate potholes and other adverse road conditions
- Thanks to larger tread blocks on the exterior of the tire, the NT421Q helps you safely navigate corners
