to purchase or not to purchase 04 z71 135K
bigelowe
hello everyone.new to the forum. i am looking at purchasing an 04 Z71 tahoe with 137k , 5.3L , leather, 3rd row, no dvd or sunroof , pass rear window does not go up or down , everything else LOOKS ok for a vehicle of this age and miles. owner wants $9800 . i currently own an 02 Z71 silverado with 169k. i know there are many similarities, but are there any tahoe specific items/problems to look for prior to purchase. also is this price reasonable?
HSpencer
NW Arkansas
I see clean, nice Tahoes retailing for anywhere from $9,500 to $15,000, depending on equipment and miles on them. The 5.3 engine is said to be able to go 200K without any major problems, and many go way beyond that. It all depends on how it was cared for. The passenger window could be simple like a switch or more expensive like a motor. A handy person could replace the motor, but I would let a mechanic do it, because I have tried this in the past, and some are not so hard, while some are. For anywhere around an 02 - 06, those miles could be ok, but anything over 100K still scares some people. See if the seller will let you run it by a mechanic for an appraisal of the engine and drive train. As most on this site will tell you, a Tahoe with a 5.3 that has had good prior treatment will be a reliable vehicle.
A private party seller would most likely ask what your saying on the Tahoe, but if I were selling for that, I would have already fixed the window. Even if I had to go and ask something like $10,200 after doing that.
For a reference, I have an 03 Tahoe LS with 2WD. It has 84,455 miles on it. It is totally clean and everything is in pristine condition. I bought it new in 03. While I would like a 08 or 10 Tahoe and new body style, I am so satisfied with the 03 I have that trading is not being considered right now. If all you need is the window repair, and the rest of the Tahoe is upscale, I would not be afraid of buying it. You might try offering him say----$8,995 for it based on the window and 137K miles. You never know he might take it.
performance1985
I would also look under the hood and see it there are any exhaust manifold bolts sheared or broken off. Since this is a common problem on the vehicles, it could be a cheap fix (couple hundred dollars), to having to pull the heads and having the bolt holes re-tapped.
I just purchased an 06 with only 59k miles on it and I can tell you first hand, I'm glad I can fix it myself - the dealer wanted $1800.
STP03Z71
Carfax, oil change, transfer case fluid replace, front rear diff fluid replaced. Seafoam, good to go
