Rumplemenz
- Oct 14, 2007
Just a heads up if people search for info on the TPS for the Tahoe 07'
If you ever change the wheels or rotate them etc you will have to reset the Tire Monitor System from the DCI on the dash.. you can do this manually and you can have this done by a shop.
Manually - It is located on page 516 of the manual - It appears to be very simple but after dozens of attempts I finally gave up! Good luck with that.. I'm not saying don't try it but if you can't do it after a few attempts dont waste your time
TMS tool - This tool is in the hands of every chevy dealer.. just a heads up.. they charge you 117 bucks to reset all 4 tires... !! it literally takes 20 seconds.. such a rip off... try and located a tire shop etc in your area that has the computer on hand.. they should do it for 1/4 of that price
GOOD LUCK
GOOD LUCK
