Tires/Wheels
the full monte
skysix
Check the thread under the following links:
"2000 - 2006 Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models" then choose
"Lift Kit and Lowering Kit Discussions" then choose
"Pic Request - 285/70/17 BFG KM2"
the full monte
Nice...thanks brother.
No probs with rubbing?
skysix
rubbing
only rubs when front end compressed and full lock or when I had 60 8x8x16" concrete bricks in the back!
the full monte
you had the BFG's on there right?
what was your opinion of the handling in rain/snow? I've read some good reviews....and some really bad ones
and I'm a little shy about shelling out 1500 bones for a wheel set up that may only last a year and a half
skysix
AT/KO's, good handling for my driving style although if you want to go fast in heavy rain they may hydroplane if you hit deep/long puddle at speed - they won't shed water as fast as a wet weather tire. They are rated for snow and ice, and in Portlands recent "blizzard" they worked fine. OK grip on black ice if carefull (but would be better if studded) but not as good as a Blizzack etc
They are (as all tires are) a compromise. But as All Terrain's go, best I've used. If you plan on more specialised use - like ice, mud, rock, sand etc then get a tire designed for that use...
