Tire sensor
richierich78
The land of broken dreams...
Ever since I got new tires a couple of days ago, my sensors have been reporting the wrong tire location. I try to "relearn" positions (to no avail).
Is there anything I'm not doing? Or do I have to put the wheels where the computer thinks they are?
Donnyballgame
Nashua, Iowa
There is a procedure spelled out in the Manual to relearn the wheel position. After you press the button on the dash, you need to get out and let a little bit of air out of each tire in the correct order. Don't forget to put the correct amount of air back into each tire when you are done.
