so does anyone have the same issue as me??
the recommended warm fill is 30 psi in the tires for our trucks; however, if the TPMS gets anything lower than 30, you get that annoying warning light on your cluster..
obviously the quick fix is do fill them up around 32 cold and all it a day.
is there any way to change the level of psi to which if under, the car will warn you?
thanks.
thanks.
