circletrack88
- Oct 9, 2013
The tire sensors on my 07 Tahoe worked fine then I rotated the tires and magically the service tire monitor light came on. I have tried resetting them per the manual 10 times why do they magically go from working then when you try to relearn them they don't work. I enter the learning mode and I have deflated the LF tire from 40 psi to 0 and go to no honk or anything. Then tried inflating them from 0 to 40 and still no honk. I find it hard to believe that rotating the tires made the tps stop working. What do I do ive repeated the process numerous times with no luck. HELP!!
