Tire pressure monitor and keyless entry stop working.
bengle
Apex, NC
For some reason my Tire Pressure monitor stopped working today as well as my keyless entry. I tried the "Relearn Tire Position" and the "Relearn Remote Key" through the Driver Information Center (DIC).
The instructions are as follows...
- Turn the ignition switch to run with the engine off
- Using the DIC press the vehicle information button until RELEARN TIRE POSITIONS message is displayed
- Press the set/reset button. The horn will sounds twice and the TIRE LEARNING ACTIVE message will appear.
When I hit my set/reset button nothing happens, it appears that button doesn't work. I see something similar when trying the RELEARN REMOTE KEY option.
Any ideas, hints or tips would be appreciated.
bengle
Apex, NC
oddly enough... I reseated the fuse for the keyless entry and the problems went away.
