Tire Chains (2006 Z71 Tahoe)
Cohoe
Can somebody set me straight on what to do about tire chains or cables (snow) for my '06 Z71 Tahoe? I've heard some mixed things, like: Never use them. I'm going to spend the winter in snow country, would like to have chains for emergency purposes, but don't want to do anything stupid.
My tires are:
BFG LT265 -70 (R17).
I know this issue has been worked over before but I could not find consistent answers.
Thanks,
Co.
Cohoe
Duh.
My Z71 Tahoe is an '04, not an '06, if that makes any difference.
Too much time in the sun I guess.
Thanks in advance for your time.
Co.
withac
Eastern Idaho
Bahollis is right, you don't want to drive too fast with them. They are good for emergency situations but not every day driving. Where I live it's not uncommon to have snow packed roads from November or December to the end of March. I used to have a separate set of tires for winter and summer. Regular tread for summer and an aggressive snow tread with studs snow for winter. I took crap from people who thought is was silly to put studs on a 4X4 but I didn't care, it was great in the snow. Nothing is perfect on ice but the studs do help a lot. That was for the pick up. When I put a lift and 33's on it I couldn't afford two sets of 33's so I just had the big suckers siped. The larger tire isn't the best on slick roads but if I drive careful I get along okay. I also had two sets for my Durango,when it got totaled (someone driving too fast for snow packed roads slid through a stop sign and nailed my wife) I needed to put new tires on the 'Ho I replaced it with. I couldn't afford to buy a set of snow tires then (it was one year ago) then buy road tires in the spring so I put on a set of real good all weather treads, something that does well in the snow but isn't too noisy or obnoxious in the summer. Since they were going to be driven all year I obviously couldn't stud them so I had them siped, if you don't have studs siping is well worth it. With that set up on the 'Ho and the 4X4 for when needed I had no problem whatsoever last winter, you just have to adjust your driving for the conditions. For that matter, I also have a 94 Bonneville. I couldn't afford two sets of tires for it either so it always only ran on a good all weather radial that was siped. Between the FWD and good, siped tires, I drove it almost daily. If things were really ugly I'd take the truck or SUV but usually I just drove the car. The biggest thing is common sense, that and watch out for the other idiot because lots of people get stupid when it snows.
Cohoe
Thank you for your responses. I thought I heard Chevy recommended against using chains at all. Wonder why?
But, an emergency is an emergency and I'll do what I must to keep from being stranded in snowy/icy conditions.
withac
Eastern Idaho
I've never looked in my owners manual to see what it says. If they say to never use them my guess would be it a clearance issue. Unless I absolutely need to travel when it's real ugly I just won't.
pstadnik
They still make tire chains??
Tire Chains are REQUIRED in many parts of the West at times. California often has chain controls on Freeways. Right now (Dec 22 storm), where I live, Portland, Oregon, Chains are REQUIRED on all city freeways.
My Tahoe is now parked on a street because I can't make it up the hill to my home. I bought chains for it, but the Right rear chain rubs on the parking brake cable. I found in the Owner's manual that Chevrolet says chains can't be used on the Tahoe - UNBELIEVABLE. I have a Tahoe and I have to rely on my Subaru to get around in this snow.
Does anybody have any recommendations for the Tahoe?
We have chain restrictions all the time in colorado, you have to run chains or have a set of dot snow rated tires. I ran some gnarly chains on my old 2wd tahoe
Now I has a garage and awd with really good tires, a set of snow cables might be a good idea tho since you can drive a bit faster than the bigger chains. I prefer security chain company products for any chains/cables.
withac
Eastern Idaho
Requiring chains on mountain passes is quite common but I've never heard of requiring them for a town, that sucks. Is it chains only or chains or snow tires? I tell ya, the 33x12.5's I have on my Ram (yeah, the D word, deal with it) suck when the roads are slick but when there's a lot of snow they are awesome. Two nights ago we got at least a half a foot over night and it kept snowing all day. City road crews won't come out until it stops. People were getting stuck everywhere you looked. I just put that bad boy in 4x4 and ran all over the place. It was sweet.
bowhunter22
Elgin County, Ontario
When running chains you must get the right size for your tire. When putting them on, get them as tight as you can. Drive a couple hundred feet tighten them again. Just to help keep them snug cross a couple heavy rubber tie downs on the radial chain, also zip tie the free end of the chains so it doesn't flail around. Low range or High range doesn't matter don't run over 25mph. Al tho your comfort level will dictate the speed threshold. If you hear anything start to hit with a rhythmic tic ,tic ,tic STOP!!! Look for loose chain or even broken laterals. Tie them to the radial chain with said zip ties, repair them as soon as possible.
Cohoe
Bowhunter22,
Your advice all makes senses to me. What doesn't make sense is the unique Tahoe restriction against any use of chains. Surely I'm not the first guy to wrestle with that one. Comments/other thoughts anyone?
AJFireman
I recall when I purchased my Tahoe new in 2006. I signed a disclosure that said I would only use cables on the Tahoe. Didnt have a reason just saying not use Chains.
You cant use chains, messes up all your electronic system, can give it too much traction and reak hell on your drivetrain. Also will slap the wheel wells. I reccommend these if you really need them, I have never tried them, but heard great things from friends who use them in snowy areas.
http://www.snobootz.com/
Rivieraracing
Oregon
There are times that chains are required to be able to drive on the freeways and even just city streets when the weather gets horrible in Portland and the outlying areas, to have to park the tahoe because Chevy or GMC says not to and not knowing why just doesn't sit well with me!!
What I do with every truck that I get a new set of chains for is dry fit them on the truck with it jacked up in the air, I fit them perfectly without slack in a perfect world environment (not on a snow covered road with the tires on the ground), I count the links dangling on the inside and the outside and make sure it is a perfect fit, I spin the tires and make sure nothing is in the way of them (like a brake line or fenders), even turn the steering wheel full left and right, both times spinning the tires making sure nothing is hitting anything. Next undo the chains and put the truck on the ground, now it is time to do it all over again but in a real world environment, run over the chains and try to get the same number of links dangling like when it was off the ground, you should be able to get within a link if not the same as it was off the ground, if not keep messing with them until you take up the slack. Once you get them the way they need to be, take them back off and the links that would be dangling on the inside and outside of the tire get some bailing wire and wire tie them to the chains where they won't stick out or be in the way at all, if real world application get you within one link, that would be how I would wire tie them( I like bailing wire instead of zip ties because more than likely you will only use that set for that truck and the wire seems to last forever unlike the ziptie), you should be able to take up the little bit of slack with the rubber tensioners you put on the outside of your tire. Cool thing about doing this is even if you don't use them for years it will be obvious how you are suppose to hook them up.
Last but not least, give it a road test, preferrably in snow, and check driving straight and turning, often times you won't encounter a problem until you get up in speed so keep your ears open for any signs of trouble.
Also, call up a service dept. at a Chevy or GMC dealership and ask them why your book would tell you not too use chains, I find that crazy except in the instance of fender clearance or brake lines being in the way, which if you set your chains up in this manner and check it you shouldn't have a problem. If is a matter of drivetrain having more grip in the front with the chains but not having chains for the back(maybe in an all wheel application), buy 2 sets, front and back (you will be an unstoppable tank for sure!!).
Rivieraracing
Oregon
By the way, we have been having some crazy snow and ice around here, we were around 2 1/2 feet where I live and I haven't had to chain up once, my denali has been unstoppable!!! I love it, I have seen big diesel trucks getting tossed around in some crazy snow and icy ruts and getting stuck in the same stuff that I powered through without chaining up, I am in love with my 6.0 all wheel drive!!!
