I had the same problem. Shut off at 65mph on the hwy. Timing chain was off a tooth. Replaced the chain, setting gear timing marks at cam gear- 6:00, crank gear-12:00. Zeroed distributor out to the (8) on the dist. housing and cannot get this to start no matter what. I have 62 pounds of fuel pressure with key on. It sputters like it wants to fire and then at times kicks back through the intake. I have 12v at the pump, cleaned up the ground, nothing. I replaced entire spider injector setup, pressure regulator, plugs, timing chain. The engine floods from cranking, plugs soaked. I heard that some of these engines the cam gear is set at 12:00? Anyone ever heard this? Any help is greatly appreciated. This is my personal vehicle and it has been laid up for a week now. It has to be something really stupid. Oh and computer shoots zero codes lol. VIN is 1GNEK13R2XJ540784. 1999 Tahoe 5.7 vortec.
