'Tighten Fuel Cap' creating a P0455 DTC
hd_ryder
Member
2004-2006 Tahoe. Has anyone had a 'Tighten Fuel Cap' message that ends up creating a P0455 DTC, and tightening or replacing the cap does not correct the problem? Did you find your EVAP leak?
So far I have replaced the Fuel Cap, vapor canister vent valve solenoid and attached hose, and vapor canister purge valve solenoid.
PNW NBS Z71
Member
Eugene, Oregon
The P0455 code just suggests tightening the fuel cap. It does not say it will fix it. That code is extensive and complicated. Check this out:
What Does the P0455 Code Mean?
Diagnostic trouble code (DTC) P0455 stands for evaporative emission system (EVAP) large leak detected. Your car’s computer will set the code when it determines there’s a significant leak in the EVAP system.
Okay, that’s great. But you’re probably wondering: what’s an EVAP system? Basically, it’s a collection of components that work together to prevent fuel vapors from escaping into the atmosphere.
Basic (non-enhanced) EVAP systems were first introduced in the1970s. In 1996, automakers began fitting new vehicles with enhanced systems that can detect a leak, then set a code, such as P0455.
The system creates a sealed environment designed to capture, store, and purge volatile fuel vapors from the fuel system.
Although system designs vary, typically, the primary components found within an EVAP system include the fuel tank, gas cap, purge valve, vent valve, and EVAP (charcoal) canister.
When the engine is off, fuel vapors are stored in the charcoal canister, rather than being allowed to escape into the atmosphere. Once the engine is running and the appropriate conditions are met, the purge valve opens to allow the vapors to enter the engine, where they are burned during the normal combustion process. The vent valve, which allows fresh air to enter the charcoal canister, is usually open unless the system is running one of its self-tests.
Your car’s computer controls both the purge and vent valves via electronic solenoids. The computer also monitors EVAP system operation, checking for leaks and other issues.
What are the Possible Causes of the P0455 Code?
Wondering what’s causing the issue? Here are some of the possible reasons why you’re getting this OBD-II trouble code:
  • Gas cap is missing, left open, or not secured properly
  • Gas cap is faulty or damaged
  • Fuel tank filler neck is deformed
  • Fuel tank is cracked or damaged
  • Fuel tank pressure sensor is faulty
  • Charcoal EVAP canister is cracked or damaged
  • EVAP hoses and clamps are disconnected, cracked, or punctured
  • EVAP vent solenoid is faulty or stuck open
  • EVAP purge valve is faulty and stuck open
What are the Common Symptoms of the P0455 Code?
You may notice the following symptoms if you drive a vehicle with a P0455 trouble code:
How to Diagnose the P0455 Code
When trying to diagnose a P0455 code, the first thing a layperson should do is make sure the gas cap is on tight. A loose or faulty gas cap can easily trigger the code. If tightening the gas cap doesn’t work, you may want to try purchasing and installing a new cap, since doing so is cheap and easy.
Keep in mind: once you’ve tightened or replaced the gas cap, you’ll have to clear the code with a code reader or scan tool afterward. The code won’t immediately go away on its own.
If the gas cap doesn’t solve the problem, you’ll need to dig further. There are numerous potential causes for OBD-II code P0455. As such, diagnosis can be difficult. For an idea of how to troubleshoot the code, check out the videos below:
How to Fix the P0455 Code
As mentioned, there are multiple possible reasons why code P0455 gets activated in your car, which means the only way to fix the issue is to look for the parts that are contributing to the problem and either repair or replace them. If your gas cap was left open, secure it, and see if that fixes the issue.
Keep in mind that all vehicles are different, so it’s extremely important that you only follow factory repair information for your application. It’s best to have a mechanic work on advanced repairs, but if you want to fix the code yourself, you may consider getting a repair manual, such as Chilton or ALLDATA to get detailed repair information.
Other Notes About Code P0455
An evaporative emission system leak doesn’t only pollute while the vehicle is running. Harmful evaporative emissions can be released into the air 24/7 from a hole as small as a pinprick. This is why it’s important to consult a licensed mechanic when faced with a P0455 engine code as soon as you have ruled out a gas cap issue.
