I have a 1999 Tahoe LT 4wd 5.7Vortec
I've been searching the forums for a possible answer to my problem but only found things close to what I'm dealing with.
My brake lights function fine(when pedal is pressed), turn signals work, hazards work, third bar works. But at night when I turn my lights on there are no running lights on my tail lights.
Bulbs are good. Headlight switch is good. I discovered that Fuse 9 labeled Crank has no power at all going to the circuit where you plug the fuse in.
Any help is much appreciated.
