stock tires seem to be rubbing on full wheel lock to the right...
why would the STOCK wheels do this, it only rubs on a right turn and only if im moving foward. hmm.
the stocks on here are those upgraded 20" crome wheels, could that be causeing the issue???
any imput is greatly appreciated.
smoothfrc
Take it back to the dealer.... you just picked it up.
I saw something on one of the other threads about some stock bushings wearing out really fast. I believe yours is a demo, so may be worth letting them check it out.
I love the turning radius of these trucks!
mine is brand new, only 200 miles on this puppy. just bought it yesterday and their closed today, im going in tues for the 2 way, my paint and interior protection, and for them to clean it, i will call tommarrow and see if that can be bumped to tommarrow.
Rafael
What's the aspect ratio and width of the tires?
Just because they're 20" rims doesn't mean that some tires wont rub
im not a wheel and tire guy. can you get in too more detail or tell me how to get that info.
thanks a bunch
beach109
Could be something else...as those are OEM on there, should be zero fitment irregularities.
smoothfrc
He said the truck was brand new with the stock tires.... That should not be a problem.
Now, if he lifted it like it says he will, that is another story. ;)
Rafael
thanks a bunch
On the side of the tire there are numbers that will say something like:
285/75 r20
The 285 is the width of the tire
The 75 is the aspect ratio, it is the height of the tire as a percentage of the tires width.
The r20 tells you what rim size the tire is for.
It is possible that the tires were not quite stock. There is very little room for the stock 20" tire as it is. If the tires were ever changed for some reason and that aspect ratio is only 5 more then I would believe it could rub when making a turn, especially if something else was going on in the suspension.
If you tell me those numbers I'll tell you if the tire size is a problem.
285/75 r20
at work now so i will look after i get home, as i dont want to drive a new truck to sit in an open parking lot all day, but i can tell you their stock since their dueilers just like my 06 had and their gmc stock 20's says that right on the window sticker. im going in tommarrow and im gunna ask, but thanks for all the help guys
Rafael
The stock 20 is a 275/55, that leaves enough room.
Rafael
Could be a bushing, ball joint, tie rod, bad coil spring, loose nut...
Possibly the alignment. Piece of plastic in the wheel well could be loose.
